08-29-2018 04:29 AM
Hi GerdW,
Not working accordingly means that the current(V-I) which is coming is not correct ( I took resistors and used 4051 to input any of the resistor and from IV graph I measured the resistance which is not correct but without multiplexer its coming all OK with keithley-2420 directly in contact with the resistor)
08-29-2018 04:31 AM
08-29-2018 04:42 AM
@GerdW wrote:
Hi jyot,
you did not wire any GND (or COM) lines between USB6501 and your CD4051 board…
Apology for that, I forgot to add it in the picture. I have wired them (gnd of USB and low keithley and and of 4051 together) and the lines of 6501 is controlled in a correct manner(say to activate p0.1 from p0.1....p0.3 I have entered 2 in the input via LabVIEW program and it worked fine)
08-29-2018 04:48 AM
Hi jyot,
So you used a DMM to check your digital outputs to work correctly?
You used that DMM to check your digital outputs are correctly received at the CD4051 pins?
When you have done that: Did you check your CD4051 board for "correctly working"? Is it ok - or is it broken?
08-29-2018 04:53 AM
@GerdWSo you used a DMM to check your digital outputs to work correctly?
Hi GerdW,
I simply used few LEDs to check whether its giving the correct output or not
Those output are received correctly at the input control (s0,s1,s2) but not at the Output of the 4051
