ni usb-232 drivers for 7
I use a NI USB-232 converter on Windows 7 Prof 64 bits. Windows 7 says that peripheral works well but MAX doesn't identify it. In MAX, I see "Manufacturer Unknow Model Unknow".
I already have installed the pack NI VISA full 5.0.1 and use the VISA Driver Wizard .
What can I do?
François
(4,251 Views)
Hi Francois,
What peripheral is it that you are plugging into the USB-232? It may just be a compatibility issue.
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(4,245 Views)
The peripheral is the serial port (RS232) from GPS Autofarm (mounted on a tractor).
I already work with this GPS and LabVIEW 7.1 and it works well. Now I 've changed my laptop (with no RS 232 port) so I try to use the NI USB-232 on LabVIEW 8.6.
François
(4,237 Views)
It still doesn't work...
François
(4,182 Views)
Hello François,
Have you tried using the NI Serial driver (http://joule.ni.com/nidu/cds/view/p/id/2056/lang/en )?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,107 Views)
Accepted by topic author GxABT_Mechanical
I've already installed this one. I contact NI Support and they found that my problem is coming from Seven. I received a way to uninstall older drivers on Windows 7 and now it's OK.
Thank you
(4,097 Views)
