07-09-2019 12:10 PM
I keep getting this error trying to run the oscilloscope "Error -200077 occurred at Property Node DAQmx Timing (arg 1) in ELVISmx_subScopeAcquire2.vi->ELVISmx_subScopeAcquireData.vi->Scope.vi"
anyone with suggestons?
07-10-2019 09:53 AM
looking at the possible reasons for this error:
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Check if your property is supported:
Error -200452 DAQmx Property Not Supported or Applicable
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MPKSA2&l=en-US
07-16-2019 08:25 PM
Version 19 of the software was the problem. I went to version 19 for the ni elvis ii+ and it worked fine.
08-29-2019 01:49 PM
Did you mean that it was version 18 that still works?
08-29-2019 07:31 PM
excuse me which version worked for them, 18 or 19
08-31-2019 12:24 PM
Version 19 created an error when using the oscilloscope. I installed version 18 and everything worked fine.
08-31-2019 12:25 PM
Sorry version 19 gave an error when using the oscilloscope. I installed version 18 and everything worked fine.
11-19-2020 04:56 AM
In my case driver 19 has the same issue. The error appears only with the scope channels, ai channels work properly
11-19-2020 06:49 AM
Hi Manushak,
What happens when you follow the recommendations given in the error message and request more than just one sample?
