01-09-2008 03:06 PM
01-09-2008 03:24 PM
In LabVIEW do Help -> Find Examples. Do a search withing find example for "digital pulse" and select VI Gen Dig Pluse.vi
Try this link:
http://zone.ni.com/devzone/cda/epd/p/id/2721
01-09-2008 03:38 PM
01-09-2008 03:47 PM
The example I sent you needs a counter that is not available on the 6008. That do you want as far as duration of the signal. Is it critical? You can send a very simple high and low using a software timer. Attached is a very simple digital pulse. You need to select the line to generate the pulse and the delay between high and low.
01-09-2008 03:53 PM
01-09-2008 04:16 PM
01-09-2008 04:45 PM
01-09-2008 04:53 PM
No problem
