new life for old LabVIEW?
I'm presently thinking about transitioning off of WinXP to something more modern.  The hangup is that I need to bring LabVIEW 5.1 with me.  Plus, I use it with GPIB instruments so I need NI488.2 also.  After some experimentation and what-not I've determined the following:
  Win7 (64-bit) couldn't even get the installer to work, compatibility thing didn't seem to help.
  Win7 (32-bit) basically pointless on multiple levels
  Ubuntu with WINE might work except for the GPIB driver issue; still investigating.
  WinXP (64-bit) couldn't install.
My question: is there something I've missed or haven't tried that would get LV5.1.1 working on Ubuntu or Win7 (in that order of preference)?  Alternatively can anyone confirm for a fact that WinXP is as far as I can go with LV5.1.1?  I know I can take the coward's way out and set up an XP partition just for LabVIEW.  Upgrading LabVIEW is also, unfortunately, not an option.
TIA,
eric
Message 1 of 10
(3,050 Views)
Hmmm.  That's a tough one.  If you are stuck with old code (LV5.1) then you might as well stick with an old OS (XP).
I'd say go for the XP partition or a virtual machine running on a Win7 host ... or upgrade LabVIEW.
Why the hang-up on 5.1.1?
http://www.medicollector.com
Message 2 of 10
(3,040 Views)
Have you search for LabVIEW 5.1 compatibility with different windows versions ?
Take a look here:
http://digital.ni.com/public.nsf/allkb/B972242574D4BB99862575A7007520CB
Sorry to say, but it seems to be that LabVIEW 5.1.1 is not compatible with Windows 7 and Windows XP.
You might be lucky to get it running on Windows XP as XP is very much like 2000. But Windows 7 has a different design/structure.
Message 3 of 10
(3,025 Views)
It's just not used enough to justify the cost of an upgrade or the effort that may be required to port the vis.
Message 4 of 10
(3,022 Views)
For certain versions of Windows 7, you can freely download and install Windows XP Mode with Virtual PC. Might just work.
Message 5 of 10
(3,016 Views)
Take a look here:
I have it running on 32-bit XP.  Couldn't get it to install on XP-64.  I saw something in an inf file or something that leads me to think the installer checks the machine's architecture.  Whether or not it actually matters, I can't say.
eric
Message 6 of 10
(3,014 Views)
That looks interesting.  Thanks for the tip.
eric
Message 7 of 10
(3,005 Views)
Something like VirtualBox OSE might work if you set up a Win XP virtual machine. I use one on my Ubuntu laptop for a couple XP-only applications.
You might run into problems getting devices to be seen though.
Message 8 of 10
(2,995 Views)
You could also use VMWare to run both the older OS as well as the old LabVIEW. The area  I think you may have the most problems with would be any drivers for old hardware. Those may be impossible to locate or not even exist.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 10
(2,986 Views)
Something not Windows-centric, nice.  Now if I can just sign onto their forum.
eric
Message 10 of 10
(2,944 Views)
