need help in tab control
Hi
I have tow VIs , I want to put them in tab control , the first Vi in the page one and the second in the Page 2 to run sparat , should I copy and paste the code of Vi on the page ?
how can I use tab control
Message 1 of 9
(3,052 Views)
A tab control is a front panel structure, typically used cosmetically to group and simplify elements of the ui. The way VIs run is decided in the diagram. Can you clarify what you actually mean?
Message 2 of 9
(3,045 Views)
Subpanels.
http://digital.ni.com/public.nsf/allkb/D587067E18E0E70186256D44007B91FE
http://zone.ni.com/reference/en-XX/help/371361E-01/lvhowto/loading_panel_in_subpanel/
Jim
Message 3 of 9
(3,029 Views)
I was initially thinking subpanels too, but then you would definitely not "copy and paste" code.... The question makes no sense. 😉
Message 4 of 9
(3,020 Views)
I am sorry if I could dont be clear
the subpanel diffrent than the tap control ,
the why I want to use tap control ? I have two diffrent tests (with the diffrent VIs) for the same sample , I want to run the first test when I press page 1 on the tap control and then I run the second test when I press page 2 on the same tab control .
Message 5 of 9
(2,985 Views)
It would be much more clear if you could attach your VI.
Message 6 of 9
(2,981 Views)
I hope I will be clear now
Message 7 of 9
(2,977 Views)
This is really horrible, but here's the basic idea.  Put the code for each test inside the Case Structure in the Event Structure handling the Value Change event.  If you're planning to write a State Machine you can have this event send the execution to a particular state.
Jim
Message 8 of 9
(2,972 Views)
VIs dont go on tab controls.
You would place regular controls and indicators that get wired to the subVIs on the diagram. You can use a case structure wired to the tab control terminal to change which subVI gets executed.
Message 9 of 9
(2,969 Views)
