09-09-2011 05:28 PM
Hi
I have tow VIs , I want to put them in tab control , the first Vi in the page one and the second in the Page 2 to run sparat , should I copy and paste the code of Vi on the page ?
how can I use tab control
09-09-2011 07:46 PM
09-10-2011 07:44 AM
09-10-2011 10:27 AM
I was initially thinking subpanels too, but then you would definitely not "copy and paste" code.... The question makes no sense. 😉
09-12-2011 11:26 AM
I am sorry if I could dont be clear
the subpanel diffrent than the tap control ,
the why I want to use tap control ? I have two diffrent tests (with the diffrent VIs) for the same sample , I want to run the first test when I press page 1 on the tap control and then I run the second test when I press page 2 on the same tab control .
09-12-2011 11:41 AM
It would be much more clear if you could attach your VI.
