06-14-2006 02:42 PM
06-14-2006 02:55 PM - edited 06-14-2006 02:55 PM
Message Edited by gatordan82 on 06-14-2006 02:56 PM
06-14-2006 02:58 PM - edited 06-14-2006 02:58 PM
Message Edited by jasonhill on 06-14-2006 02:58 PM
06-14-2006 03:35 PM
06-14-2006 03:48 PM
06-14-2006 03:52 PM
06-14-2006 04:22 PM
You just need to build new arrays, containing only the "in range" data.
Attached is a very quick&dirty implementation that should get you started. It clearly needs more work, especially when switching plots etc. Also, if your arrays have significant size, you should avoud the built array nodes and use soemthing more efficient.
I don't have a datafile, so I cannot test, and it's probably full of bugs. Just modify as needed.
06-14-2006 04:45 PM
06-14-2006 04:55 PM - edited 06-14-2006 04:55 PM
(To read decimal data, set your format to %f instead of %d)
However, don't complicate things, just use "read from spreadsheet file". 🙂
Message Edited by altenbach on 06-14-2006 02:56 PM
06-15-2006 02:04 PM
