ncSetAttr not working when setting Transmit mode
Highlighted
I am using a NI-USB 8472 (low speed CAN @ 33333kbps) device and am trying to set it up for the wakeup mode which states in the devices spec that it has this capability.  However, attached is the quick test code that returns and error when using the ncSetAttr.vi to change the transciver mode from normal to wakeup
The error returned from the ncSetAttr.vi is 0xBFF62104: The property ID, attribute ID, or operation code that you provided is invalid.  Solution: Read the function description and verify that you provide ad valid ID.
As far as I can see I have everything configured and set appropriately for it to work.  Anyone that could help out with why the hardware is not properly being configured for this mode would be appreciated.
(798 Views)
Highlighted
Duplicate Post
Simran K
(774 Views)
