myRIO reads I2C's WII nunchuck just can get the first byte
to title,WII nunchuck i2c have 6Bytes data,but  I can only read the first byte.
How should I modify.thank you
(877 Views)
Dear an7723,
Why did you use the wait until next timing in the loop?
best,
anasei.
(756 Views)
Thank anasei
I use wait until next timing in the loop to continuous execution.
thank your response.
(741 Views)
Hi an7723
Could you please attach the VI as well to be clearly?
What I suggest you probe the array output and see the behavior. Also try tackle the problem step by step. Meaning, try sending just one message. If that succeeds, try sending two... and so on.
Regards)
________
Best way to thank is giving Kudos / Marking as a solution.
(686 Views)
