myRIO not found
Hii, I want to getting started with myRIO 1900 and I follow the instructure in https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8bpSAC but I can't getting started with myRIO . the error program you can see this picture below. hope you cant help me. thanks
(2,368 Views)
Hello vivien.y,
It's a little unclear from your message, were you able to do any of the troubleshooting steps in the document you linked? What are you doing when you see the error message? Are the lights on in the myRIO showing that it's connected?
ZK
Technical Support Engineer | NI | Not actually retired but I don't know how to change that
(2,337 Views)
I have taken the troubleshooting steps according to the document in the link. but myRIO is still not found on PC. error can be seen in the picture below. before connect to PC, color light status in myRIO is red color. after being connected to the PC , light status  is not on.
(2,326 Views)
Sounds like the device drivers are not loaded correctly.  Have you looked at Windows -> Device manager -> USB Devices?  Anything that says "myRIO"?  i am not  a myRIO expert but most USB issues are related to device drivers.
Additional;
Try a different USB port
Don't use a USB HUB
Do a full shutdown and restart PC, then when fully booted, plug in USB to mtyRIO
Hope this helps,
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(2,316 Views)
