myRIO analog input express Vi (n samples) missing file
Dear Users,
I am trying to read analog data with an express VI in myRIO. This works with Analog input (1 sample), but fails with Analog input (n samples) due a missing file "myRIO v1.1 FPGA Throughput.lvbitx".
I googled it and searched it on ni.com, but nobody seems to have the same isssue (I suppose because of the myRIO is quite new right now)
Thank you!
 missing "myRIO v1.1 FPGA Throughput.lvbitx"
(5,884 Views)
I would try doing a repair of your installation.  It looks like something didn't get installed properly.
(5,867 Views)
I don't have that bitfile in my installation of the myRIO software.
Installed with LabVIEW 2013.
(5,860 Views)
Thanks, but i tried to install the whole LabVIEW toolchain (RT,FPGA,myRIO, etc) on a another PC but it did not worked for me. Btw I use LabVIEW 2014.
(5,853 Views)
Accepted by horverno
Ok, now we have a solution. The problem was, that  the High throughput FPGA personality is not part of the default install. You have to download the NI High Throughput Add-on for myRIO 2014 (which is ~20 MB) and now it works. The link for the download is: www.ni.com/download/ni-myrio-software--2014/4938/en/ .
(5,803 Views)
Good night
I need help with the waveform of the signal to the analog input. A little deformed shown. Myrio only reads the values 0-5 v. There is a better way to me waveform that is presented in the chart wareform
Buenas Noche
Necesito ayuda, con la forma de onda de la señal que va la entrada analógica. Se muestra un poco deforme. La myRIO solo lee valores 0-5 v . Existe la manera de me mejor la forma de onda que esta presentado en el wareform chart
(5,404 Views)
First, you should have started your own new thread. This thread has nothing to do with your problem.
Second, the port your are using CAN'T measure any voltage below 0!
If you need to measure any voltage below 0 volt you need to use the C connector. There you can measure from +10 volt to -10 Volt. Use pin 7 and 8 for that.
From what I can see on your chart your signal is a sine wave around 0 volt.
(5,384 Views)
