05-10-2011 09:24 PM
Hi everyone,
I would like to create a case structure which will operate when there is a true value of a multiple of 24. Can someone pls help me out??
Thanks a lot for your effort.. 😉
Ray...
05-10-2011 09:29 PM
you might find the LabVIEW help files, shiping examples, tutorials or
your professor's sylabus helpful. did you inspect any of these referances?
05-10-2011 09:38 PM
As you can see above, the while loop will keep operating and I want the case structure in "True case" whenever the iteration +1 is equal to the multiple of 24. I am doing a project to pass the data to another table of database whenever the "True case" comes out. It's like when it is "24" hours a day, all the data will be passed on to the daily table. Can you please help me out?? thanks
05-10-2011 09:48 PM
You need the Quotient & Remainder function. Same as modulo operation in text laguages.
05-10-2011 09:51 PM
Hi As i'm not so familiar with Labview, can you please demonstrate that funtion for me?? Maybe a .jpg picture...thanks a lot
05-10-2011 10:03 PM - edited 05-10-2011 10:05 PM
Read the help on the function and run the VI. It will count 0-23 and start over. Read about Modulo operation.
05-10-2011 10:04 PM
It is a very basic LabVIEW function, and as you aren't familiar with LabVIEW I will hint that you should look on the numeric palette on the diagram. If you enable the context help on the diagram page, it will explain how the Quotient & Remainer function works. You will not learn LabVIEW without trying to find the answers yourself. We will help, but not do the work for you.
05-10-2011 10:31 PM
Thanks a lot for ur effort,Sir. I really really appreciate your kindness and hoping you to help me in my future problems
With loads of regards,
Ray
