12-21-2006 02:54 AM
12-22-2006 05:06 AM
Hello Daniel!
I am not sure which FPGA target you are currently using but one method to achieve what you want it to use the Up Cast method. If you use cRIO you have an example called ‘Using the Upcast Function - cRIO.lvproj’ and if you use R-Series look at the example called ‘Using the Upcast Function - R Series.lvproj’. Hope this helps and Merry Christmas!
02-13-2007 07:22 AM
02-26-2007 06:34 AM
