multichannel sound card access
Hi, I make application in LabView 8.6 for multichannel sound card MOTU 896HD. If I get audio device list over directX, I see every two channels has different device id (1-2 analog output, 3-4 analog output, ...). I want to ask how I send different signals to more outputs at the same time. Thanks Vanis
(2,388 Views)
Hey Vanis,
  Please could You verify how You communicate with the MOTU 896HD! I just not want to miss any important point. Are You using ActiveX? Did You find a driver for this device for LabVIEW? For the first sight this question seems to be more to the hardware specific and the manufacturer might have more precise answer for it. Did You try to contact them? Of corse we will try to do our best to help as well!
David Varga
NIH
(2,358 Views)
