marconi,
That will depend on the frequency of the PWM signal you are trying to monitor. Depending on the frequency, you will need either one or two counters per PWM signal. I've attached several charts from the NI-DAQmx help that demonstrate what kind of quantization error you will see at certain frequencies on each of the three possible frequency measurement types. You will need either 12 or 24 counters. Unless you want to add other functionality, like counting the pulses as well as measuring the frequency. This Developer Zone article explains how many counters are needed for each measurement type.
One Counter - Low Frequency
Two Counters - High Frequency
Two Counters - Large Range
Message Edited by Seth B. on 01-20-2009 10:21 AM
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
