03-31-2022 12:49 AM
hola necesito ayuda necesito Realizar un VI que permita controlar un motor a pasos (bipolar o unipolar). Debe agregar un control que permita seleccionar si el giro es a medio paso o a paso completo. Agregue un control para seleccionar la dirección de giro, a la derecha o a la izquierda. Todo el proceso debe iniciar una vez que se presiona un pulsador llamado “Iniciar”. Utiliza los drivers de potencia correspondiente. Anexe la información correspondiente a motores a pasos.
No tengo idea de como empezar ayuda por favor ;(
03-31-2022 04:06 AM
Hi Keved,
@KEVED20 wrote:
hello I need help I need to Make a VI that allows to control a stepper motor (bipolar or unipolar). You must add a control that allows you to select whether the turn is half step or full step. Add a control to select the direction of rotation, right or left. The whole process should start once a button called “Start” is pressed. Use the corresponding power drivers. Attach the information corresponding to stepper motors.
I have no idea how to start help please ;(
According to your message I guess:
Creating a VI with some buttons and some code to react on those buttons is pretty basic LabVIEW stuff.
What have you tried so far and where are you stuck?
