05-27-2008 11:57 AM
05-28-2008 05:35 PM
Hi xciene,
In order to reset/clear the graph ever time you run your VI you can use a invoke node for your graph to programmatically call the "Reinitialize to Default Values". To manually reset/clear your graph you can right click it on the front panel and select Data Operations >> Reinitialize to Default Values. However to do it programmatically follow this process:
If you nagivate through these property/invoke nodes for controls and indicators you can find that alot of the items that you do manually can be automated. I hope this helps direct you down the right path. Thanks and have a great day!
Cheers,
Jonah
05-29-2008 05:45 PM
