10-02-2014 03:51 AM - edited 10-02-2014 03:52 AM
I have a PCB impact hammer (ref 086D20) connected to card NI 9234. I want to interpret the voltage measurements (in Volts) to force (in Newton). I tried to multiply the hammer sensibility (0.23mV/N) by the voltage values but it seems that is not correct. For the purpose of using Matlab to write a standalone executable application, I don't want to use others intermediate programs (for exemple NI LabView or LabView Signal Express).
So, I'm looking for a method, more specially an algorithm, to convert the voltage to the force. Someone can help me ?
Thank you
10-02-2014 04:04 AM
Hi newbie,
- how do you read the sensor data? What are the specs for this measurement?
- How do you come to the conclusion your voltage values do seem incorrect?
- How does Matlab come into this topic? Why don't you ask in a Matlab forum when you want to use this IDE?
You need to apply all specs given in the sensor's manual…
Or ask PCB as they offer "Total Customer Satisfaction"! 😄
10-02-2014 04:33 AM
Force [N]=(1.0/(0.23*1000)) * Voltage [V]
Agreed in principle this question is nothing to do with LabVIEW.
10-02-2014 06:39 AM
In fact, my question is indirectly related with LabView (especially LabView Signal Express). Before using Matlab to write my application, I used LabView Signal Express to test my system (PCB impact hammer and NI 9234). When I choose the voltage as my analog input signal, I have a curve of voltage according to time. This cuve contains many positive and negative peaks (I did just one shock of hammer). However, when I change the kind of input signal to force (N), i obtain a new curve that contained just one positive peak. This result corresponds well with my test in which there is just one shock of hammer.
Through these 2 tests, I think that must have a method to convert the voltage measurements to force, and that is not simple as multiply the voltage by a constant (sensibility or sensibility^-1). It must be something more complicated. I readed the documents of LabView Signal Express, but I cannot find the method on which this sofware based on to interpret the voltage to real force.
