02-14-2007 05:50 PM
02-15-2007 07:51 AM
HI,
Hopefully these 2 tutorials will help you to understand the different VI's for spectral analysis and the way they work:
http://digital.ni.com/public.nsf/websearch/8B09A4DE6805112186256D36007943D4?OpenDocument
http://www.ni.com/support/labview/toolkits/analysis/analy3.htm
02-15-2007 08:12 AM - edited 02-15-2007 08:12 AM
obarriel,
Like the above links say, the Fourier transform of a signal will be a symmetric graph. All of the negative harmonics will be same as the positive (same amplitude, shape and frequency offset) only in the negative portion of the frequency domain. They really only have Mathematical significance (how can you have a tone at -3000 Hz?), but if you need them then repeat the set of positive harmonics, keep their amplitude identical and make their frequencies negative.
Or, you might already have the negative harmonics and not realize it. If you are getting only positive signals, the 'positive' side is the frequencies up to your Nyquist frequency (half your sampling frequency) and the signals above that, are the 'negative' half of your harmonics, which have wrapped around.
Message Edited by Mellobuck on 02-15-2007 08:17 AM
