09-30-2013 11:32 PM
I need to merge a few data sets together, they were taken from different DAQ systems, and have different time stamps (sampling rates) associated with them. So, I'd like to put them all together in one file, but have the data points all spaced out correctly (just padding the data on the slower sample rate data). Does LabVIEW have any tools for merging data like this?
much thanks!
10-01-2013 12:09 AM
LV doesn't have a complete tool for doing this sort of resampling, but it does provide all the functions necessary to build one. The two functions you will need are the ones for threshold (to calculate a fractional index of a point), and then interpolate (to calculate a new data value associated with that fractional index).
The basic process is called resampling a signal.
Mike...
10-01-2013 08:58 AM
Thank you, I will look into these.
10-02-2013 07:20 AM
Actually, LabVIEW has several tools for resampling full waveforms. Do a search for "resample" in the palettes. I got three Express VIs and seven normal VIs (your mileage my vary depending upon what you have installed). Use the one which best fits your needs. You need to do three things:
Good luck. Let us know if you run into issues.
10-02-2013 02:57 PM
Awesome, thank you!
