08-29-2012 01:35 PM - edited 08-29-2012 01:43 PM
I'm sure this has been discussed many times before, for instance the old clear as mud thread and the more recent nugget on the same topic, but I was hoping for some confirmation for my particular case.
I am currently constructing a multi-plot XYGraph from a 'super-cluster' in a particular manner which is easy to add data to, but seems a bit convoluted to update. So I thought of arranging the data in the cluster in a different way, which makes it very easy to update the graph but a little more long-winded to update the data. (see VI for details)
I then constructed a timing setup to try and work out if one way was considerably faster than the other or not. However it seems that the timing outputs aren't completely consistent. I was wondering if someone could point out what I'm doing wrong? (Also, I noticed a general performance hit when I added in the Diagram Disable Structures. Is this expected?)
In addition to how fast each things executes (okay, Im' not dealing with huge arrays, but I was still curious), I want to bear in mind how easy it is to use each method in my project code. Is one way necessarily better than the other from a design point of view? The big clusters to the left were taken from the project I'm building, but had all the non-essential arrays emptied.
So, as in the title, which method is better in terms of memory usage, speed, and ease of use (or best practice), and what may be wrong with my timing setup to produce slightly inconsistent results?
Picture of BD:
Thank you.
- James
P.S. Apologies for the large BD size. I wrote this in a hurry!
08-29-2012 01:59 PM
You didn't attach the controls. Anyway the timing will never be consistent unless you are using Real Time. You should look into LVOOP - it's just clusters and VIs that can access the clusters. Check out the composition pattern. That means you have a class that contains other classes as it's data. This is analogous to a cluster of clusters.
08-29-2012 02:11 PM - edited 08-29-2012 02:12 PM
Hi J,
general notes:
- don't do speed measurements for parallel running loops
- in the lower loop you could use the InPlace structure. It may help for "ease of use" as well as speed and memory... (Instead of IndexArray/ReplaceArraySubset combination and also instead of Unbundle/Bundle combination!)
08-29-2012 03:45 PM
Boy do I hate when people say this. Object oriented programming is a bit more than that. While at it's simplest definition an object is the "data and the methods that act on that data" the power of OOP comes from how classes are defined, what your inheritance is and how well you keep things decoupled. An analogy would be to say a building is just a bunch of materials all put together. You might be able to hobble something together but the results can be disastrous if not done right.
08-29-2012 05:56 PM
08-29-2012 07:38 PM
@GerdW wrote:
Hi J,
general notes:
I've been having a read through of various help files and some online documentation about LVOOP, but am not entirely sure what I could actually use it for. The LV examples weren't particularly helpful in that respect (or maybe I was looking in the wrong place). I have had some experience of MatLAB's object-oriented programming styles, and I picked LabVIEW up fairly quick. Maybe I'll be able to get my head round LVOOP too.
08-30-2012 04:05 AM
But it's better to start by building a shed then by trying to build a skyscraper. Like Steve, I recommend people start by just using LVOOP as a nice clean way of doing typedef clusters plus VIs that operate on those clusters, with benefits like wizards to create new VIs and pretty wires. Then appreciate the key advantage that the cluster can be passed around by anyone but only unbundled by it's own methods. Then try a very basic parent-child thing (a simulated instrument driver, say). Work your way up.
-- James
08-30-2012 08:29 AM
08-30-2012 09:35 AM - edited 08-30-2012 09:39 AM
J.Mamakos, the VI was broken. When I listed errors, it said thee were three missing controls. I didn't see them on the block diagram or front isabel. When I double clicked in the error window it hilighted an empty area at the top of the code. There was nothing there. Sorry but I am on my phone and don't remember the names of them. Just put the VI in an empty project and look at the dependencies.
Ah, it was trying to link to a couple of type def controls from which some of the constants had originally been derived. Sorry for my confusion; it hadn't occured to me that they were even still linked!
Attached is a .zip file of the vi and the three controls.
P.S. That Timed Sequence structure I found actually looks a bit complicated! I'd still like to get this hand-made one working better, though.
P.P.S. The In Place Element Structure seems useful so far, though I can't tell if it speeds things up at all.
