memory leak in subpanel
Hello Guys I have hit a brick wall , I finished 2 VI which are used to control a training module for my college, the problem is that they asked me to use them on a sub panel and thats where Im lost.
Each VI runned on its own uses 200-350 MB of ram in prolonged use, but as soon as I add them to the VI the consumption rises to 3 GB. I will add the diagram code of each of the VI im using
(3,677 Views)
Sounds like you have a memory leak but without seeing what's going on in the other cases of your code it's not possible to see where the problem is.
Memory leaks usually occur when you have a loop that either continuously builds an array or opens references (e.g. device, .NET, VI) but doesn't close them.
The desktop execution trace toolkit is a great way of seeing where references are created and left open.
(blog)
(3,674 Views)
Yea Let me add the VIs, in there you have both VI and controls and the VI using for calling them
(3,653 Views)
Hello guys Found the solution to the problem will be posting soon
(3,619 Views)
I'm curios to what the problem was.  Could you please post your solution?
Thanks.
CLAD
(3,472 Views)
