measurement problem in Keithley 2635
hi, all
I use a Keithley 2636A to do measurement only, that is direct measure voltage or current. Input connected to channel A
My question:
   when I changed measurement from voltage to current, or versa vice,  in first few readings, are just same as that of previous measurement (for examples, If I switched measurement from voltage to current, in the first few readings, I still got the voltage data, and later on, I could get the correct current readings.). Because I did not use buffer to store data, why the data still buffered? I use print(smua.measure.i()) or print(smua.measure.v()) to read the current or voltage directly.
In the each measurement beginning and end, I had issued a command smua.reset() to reset the instrument, respectively.
Anyone any suggestion would be appreciate.
-yuxj
(4,031 Views)
If you use C to program your Keithley, you probably contact Keithley, http://www.keithley.com/support, directly, but if you use LabVIEW, could you please attach your code, and 2636a command set so that we can further assist you to analyze the problem?
(4,007 Views)
Thanks! I use labview.
command sent to 2636 for voltage measurement
;initialize the 2636 in the measurement beginning
localnode.prompts=0
reset()
smua.measure.nplc = 1
smua.source.func = smua.OUTPUT_DCAMPS
smua.source.leveli = 0.00000E-9
smua.source.limitv = 20
smua.measure.rangev = 20
display.smua.measure.func = display.MEASURE_DCVOLTS
display.screen =display.smua
format.data = format.ASCII
smua.source.output = smua.OUTPUT_ON
;measure loop cycle, to read the data in some tie delay
;when the measurement finished
smua.source.output = smua.OUTPUT_OFF
smua.reset()
command sent to 2636 for current measurement
localnode.prompts=0
reset()
smua.source.func = smua.OUTPUT_DCVOLTS
smua.source.levelv = 000.000E-3
smua.source.limiti = 2E-3
smua.measure.autorangei = smua.AUTORANGE_ON
display.smua.measure.func = display.MEASURE_DCAMPS
smua.reset()
(3,996 Views)
This is C code.
Not LabVIEW.
(3,990 Views)
These are ascii command sent to 2635 in labview program, but how to post labview program code?  it is some graphic block.
The labview prorgram runs normal, but the a few data readings are not correct in a new measurement.
(3,988 Views)
attach the file.
(3,985 Views)
