01-07-2010 11:29 PM
Dear All,
I have installed labview2009 evaluation version, After installing Measurement & Automation explorer is now showing any software installed in Mysystem>>>Software tab.
I reinstall DAQmx but problem is same.
Any one can say what could be the problem
--Vishnu
01-07-2010 11:34 PM
Here i am giving screen shot of explorer.
01-10-2010 09:58 PM
Go to control Panel >> Add remove programs >> National Instruments software:
In it you if you can find NI- DAQmx drivers software uninstall it.
Re-install the DAqmx drivers using the Platform DVD you have.
Hope that should solve your problem!
01-10-2010 11:03 PM
Thanks Shreyas,
I tried that but i couldn't succeed. I forgot to tell you that when i start Measurement & Automaiton explorer there is an error comes.
This is the error.
Is this any relation with this.
--Vishnu
01-12-2010
02:52 AM
- last edited on
05-29-2026
08:36 PM
by
Content Cleaner
have a look at this
01-18-2010 11:03 PM
I Tried but still problem is there.
--Vishnu
02-01-2010 02:49 AM
Dear Shreyas,
Thanks for your reply, I tried that but not working.
I finally reinstalled LabView 2009 Evaluation. It was working fine. But after i run MAX 2-3 times it again give same problem. But this time the message popup
"The application failed to initializw properly (0x0000142)" and title of error is nidevmon.exe could not start.
--Vishnu
02-01-2010
10:10 PM
- last edited on
05-29-2026
08:37 PM
by
Content Cleaner
It seems that it could be a virus problem. Can you run MAX with administrative privileges/ Admin Account?
You might want to debug this way.
