measurement and automation is not showing software in software tab
Dear All,
I have installed labview2009 evaluation version, After installing Measurement & Automation  explorer is now showing any software installed in Mysystem>>>Software tab.
I reinstall DAQmx but problem is same.
Any one can say what could be the problem
--Vishnu
Message 1 of 8
(4,852 Views)
Here i am giving screen shot of explorer.
Message 2 of 8
(4,851 Views)
Go to control Panel >> Add remove programs >> National Instruments software:
In it you if you can find NI- DAQmx drivers software uninstall it.
Re-install the DAqmx drivers using the Platform DVD you have.
Hope that should solve your problem!
Shreyas Hebbare
Shreyas Technologies
India
Message 3 of 8
(4,806 Views)
Thanks Shreyas,
             I tried that but i couldn't succeed. I forgot  to tell you that when i start Measurement & Automaiton explorer there is an error comes.2.JPG
This is the error.
Is this any relation with this.
--Vishnu
Message 4 of 8
(4,799 Views)
have a look at this
Shreyas Hebbare
India
Message 5 of 8
(4,767 Views)
I Tried but still problem is there.
--Vishnu
Message 6 of 8
(4,710 Views)
Dear Shreyas,
             Thanks for your reply, I tried that but not working.
              I finally reinstalled LabView 2009 Evaluation. It was working fine. But after i run MAX 2-3 times it again give same problem. But this time the message popup
              "The application failed to initializw properly (0x0000142)" and title of error is nidevmon.exe could not start.
--Vishnu
Message 7 of 8
(4,613 Views)
It seems that it could be a virus problem. Can you run MAX with administrative privileges/ Admin Account?
You might want to debug this way.
Shreyas Hebbare
India
Message 8 of 8
(4,593 Views)
