measure transition time in graph indicator automatically
hello. please help me. I want to measure the rise time for the two graphs (see picture). i also need the decent time. is there a way to interpolate the graphs?
please help me.
THX
(2,681 Views)
Hello 0123,
If you are using LabVIEW professional, you can use the transition measurements.vi, which offers a lot of functionality.
Transition Measurements (Not in Base Package)
Accepts an input signal of a single waveform or an array of waveforms and measures the transition duration (rise or fall time), slew rate, preshoot, and overshoot of a selected positive or negative transition in each waveform. The data type you wire to the signal in input determines the polymorphic instance to use.
Otherwise try with Timing and Transition Express vi.
regards
Message Edited by IngoS on 02-01-2006 02:57 PM
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(2,653 Views)
