measure percentage
Highlighted
If you have an array of volts, simply wrap a FOR loop around the interpolate array function. The rest stays the same. You will get an array of percentages.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 21 of 43
(465 Views)
Highlighted
If you are getting an array of data from the daq, why do you want to throw away everything except a single point? Wouldn't it make more sense to take the mean? Of course, if your daq setup is to take just a single reading, then it is pointless to convert to a 1D array.
Message 22 of 43
(464 Views)
Highlighted
Here's what I had in mind:
Message 23 of 43
(463 Views)
I follow you suggestion but it shows error...maybe I'm misunderstanding what you mean...VI.png
And also I attach the program that I mentioned just now which cannot show charge percentage.
Could you just do correction in this VI??
Millions of Thanks!!!!
Message 24 of 43
(434 Views)
Highlighted
Try to do this yourself.
Message 25 of 43
(420 Views)
Highlighted
Try this.
(These are very basic programming concepts. Try to do some some tutorials)
Of course you could just take the mean if the array and eliminate the FOR loop again. How rapidlty does the voltage really change? How many points do you take?
Message 26 of 43
(417 Views)
Highlighted
I try this VI but while I change the voltage, charge % remains 0%...
Is it must in array?? Actually we only want the charge % for further calculation.
If the charge % in array, how could we do our further calculation??
e.g when it is 12.5V, we could get 90%. And through another way we get the SOC of 80%. We need to get the ave of these two data...
Message 27 of 43
(412 Views)
Highlighted
If you have an array of N measurements, you'll get an array of N charge percentages.
As I mentioned, you can reduce it to a single number by taking the mean, for example.
How do you change the voltage. Is the voltage reading correct?
Message 28 of 43
(392 Views)
Highlighted
how to take the mean to get the single value???
we now connect daq to a power source which can decrease or increase.
If connect to battery, the voltage will also decrease.
Message 29 of 43
(385 Views)
Highlighted
Use the mean function (if this is difficult for you, you really need to start with LabVIEW basics!
In what way is this relevant? You need to be much more specific!
Message 30 of 43
(363 Views)
