measure percentage
Hello everyone! I'm doing on our project on labview. We are using a battery and need to measure the percentage of power that the battery left. As the power used, the voltage will also decrease. Here is a table of the relationship between voltage and percentage. Can anyone help me to get the vary value of percentage? Thanks!table.JPG
Message 1 of 43
(1,596 Views)
Highlighted
Are you having a problem with LabVIEW problem or a problem with math? What have you tried so far?
LabVIEW Champion. It all comes together in GCentral GCentral
Message 2 of 43
(1,587 Views)
Both the problems...How to get the formula of the table? Then how to program on labview?
Message 3 of 43
(1,579 Views)
So what you mean here is, you want to display the exact percentage of battery depending on the voltage (Suppost 11.23 V mean 54% like that)? You can do a Linear fit (LinearFit.vi) with the Voltage as Y values and Percentage as X values (Or may be the other way) and find the Slope and Intercept. Then with the voltage reading Mulitply the slope and Add the intercept, you are done.
Message 4 of 43
(1,578 Views)
Create an array of points (cluster of xy pairs, x=voltage, y=%), then use interpolate array with the given voltage.
Message 5 of 43
(1,573 Views)
Actually it is not a linear one...
Message 6 of 43
(1,542 Views)
Maybe a curve.
Message 7 of 43
(1,541 Views)
Hi xuan,
either use Altenbach's suggestion (with linear interpolation between your data points) or calculate a polynomial regression of your choice. Then use PolynomialEvaluation function to calc battery state from voltage…
CLAD expired, using LV2011SP1 + LV2017 (+LV2019 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
Message 8 of 43
(1,530 Views)
Using a lookup table as Altenbach suggested is the easiest way to go.
GCentral
Message 9 of 43
(1,513 Views)
I'm sorry...Can u give me a more detailed solution?
Message 10 of 43
(1,481 Views)
