03-18-2010 01:06 AM
Dear frd,
I have connected three PC in LAN which are the part of a distributed system. 3 PCs connected with a server PC, Now each PC gives a output file in .mbd (Programmed in LabVIEW DB toolkit and System DSN)form, on server PC I have to call .mbd file of Each PC and make decision on that basis.
I am using System DSN to save file on different PC and while applying on server PC it gives a error : 0.80004005
please give a solution .
03-18-2010 01:43 AM
controling of induction motor wrote:Dear frd,
Next time when you are posting please increase your text font.
OP: I have to call .mbd file of Each PC and make decision on that basis."
Mathan: What decision you want to make?
OP: I am using System DSN to save file on different PC and while applying on server PC it gives a error : 0.80004005
Mathan: What do you mean by applying on server PC?
03-18-2010 01:46 AM
If you want to access the mdb file in your DSN you have to make it available through the file system. Create a common file share on all computers pointing to the directory where your mdb file is located and configure the DSN to point to that share.
