matlab neuronal net
Hello this is my first post, im new in labview, so I need some help with my proyect,
I aready have a trained Nerural Net in matlab, but i want to export the net to labview and test some files
(2,714 Views)
Hello Borreboy,
In LabVIEW you can use a MathScript node to evaluate scrips created in MatLab. You can run .m file scripts allowing you to add knobs, slides, buttons, graphics, and other user controls and indicators.
Here is a link that can help you to have a better understanding about MathScript nodes. Also refer to the LabVIEW help section for more information about these nodes.
http://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/scriptnodes/
In the find examples section of LabVIEW there are several VIs that you can use to understand in a better way the MathScript node (look for MathScript in the search tab).
Hope this helps!
Luis C.
Ingeniería de Aplicaciones
www.ni.com/soporte
Luis CT
(2,669 Views)
