mass compile operation keeps on looping
hi,
when i do  a mass compile on my  project ,  it keeps on looping  during a save operation
and it does that may be a 50 times & eventually  ends also without error.
the curent file remains the same
Message 1 of 11
(3,805 Views)
I've only seen this in projects in which I use LVOOP, I suspect that the whole class is reloaded and recompiled for each of its VI's call or something like that ; maybe though I'm just plain wrong (like often).
Anyway, whatever the reason is, it's pretty annoying and make me think twice before I mass compile a project.
I do consider posting an idea to improve the mass compile function.
Epictetus
Antoine Chalons
Message 2 of 11
(3,798 Views)
Just as TiTou said: it looks like recompiling each VI which depend on any class hierarchy makes LV recompile each VI of this hierarchy, and then each VI of this class makes recompilation of each other VI, etc... As a workaround you can try closing the project and mass compile project folder from Tools->Advanced menu. I noticed this does not loop as much as there are not all dependencies loaded, but there are many more factors to this (i.e. how you managed libraries and classes dependencies). Furthermore, this might not give you exactly the same effect as mass compiling the project (same reason - not all dependencies are loaded).
Message 3 of 11
(3,793 Views)
Good catch!
Epictetus
Antoine Chalons
Message 4 of 11
(3,785 Views)
ya u guys r right
I am using LVOOP    in this project
any solution or workaround  in sight
Message 5 of 11
(3,763 Views)
Hi, Maybe you have to change the instances of the class throughout your VIs. This is a time-intensive process, but there is no way to change all of the instances with one click of a button. The officially recommended process of renaming a LabVIEW class is listed here ( http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/renaming_files/ ). Because LabVIEW is such a high-level language, renaming files in Windows Explorer may lead to dependency issues. Regards, Julika Spitz
Message 6 of 11
(3,622 Views)
How exactly changing the names of the classes would help in this case?
Message 7 of 11
(3,512 Views)
Sometimes this can solve problems, which occur when mass compiling, but musn't be the solution to this problem.
Message 8 of 11
(3,485 Views)
hi aparab,
Have you found a solution to this problem?If so, can you let me know
Message 9 of 11
(1,972 Views)
hii there,
i have changed my job 2 times in between so cannot give you a concrete reply.
I think with new tststand versions it should work.
best,
akshay
Message 10 of 11
(1,938 Views)
