From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
02-07-2014 11:58 AM
Hi Johnsold,
Actually, I am trying to run the code but give me an error state that error -200479 occured at DAQms start as can be seem in atached file.
Khalid
02-07-2014 12:30 PM
Khalid,
The error message tells what needs to be done. First note that both DAQ tasks are set to continuous samples. A task that is set to continuous samples is done when? - When all the samples have been processed. When is that for continuous samples? Never. So I think you need to remove the Start Task VI in the event structure. These are the kinds of mistakes which occur because I do not have DAQmx and cannot test things.
Lynn
02-07-2014 03:21 PM
Hi Lynn,
I have removed the stsrat task in the event structure. However, i still get an error state that Error -200292 occurred at Synchronized AI and AO FRF_New (2).3 (1).vi, as can be ssen in attached file.
Khalid
02-07-2014 03:22 PM
sorry I forgot to attach the image of error.
02-07-2014 03:56 PM
Now you are getting into areas where I have no experience. Perhaps someone else will step in with suggestions.
Lynn
02-07-2014 04:02 PM
02-07-2014 04:38 PM
Perhaps the best approach would be to start a new thread in the Multifunction DAQ Board. Link to this one and perhaps your other thread so that people can see what you have already done.
Lynn
