You can do that with sift register in the case you need
only short term historic data, or you may use vague array
data with +1 dimension to a numeric, in which to put
historic data sequencially to the loop counter by replace
array element.
A little sorry for miserable grammatical conditions(-;),
Tom
Reik2001 wrote:
> How do you make a numeric control( or indicator) display a scrolling
> present value+ x number of the past values as the vi runs?
