11-29-2006 04:41 AM
04-20-2014 09:14 AM
同问!
04-20-2014 11:58 AM
The oriinal question was 8 years ago. Are you still using LabVIEW 8.2?
The current evaluation version is LabVIEW 2013, so try that!
04-20-2014 07:38 PM
I'm using LabVIEW 2013 now, but I encounter the same problem.
Now I'm reinstalling my LabVIEW for I can't find another solution.
04-28-2014 11:55 PM
I have tried labVIEW2013 and labVIEW2012, but still the problem exists. Don't know how to fix it.
and it just keep popping up for dozens of time until it finally comes to an incomplete and blank component:
04-29-2014 12:35 AM
04-29-2014 11:12 AM
Hi, thank you for your reply!
I have just fixed the problem! I have replaced all the content in "D:\Program Files\National Instruments\Shared\MKL" with another copy from my classmate who has successfully installed labVIEW2012. And it worked!
The problem was that when I tried to add an "simulation signal" component in the Block Diagram, an error message kept popping up indicating an error in loading "D:\Program Files\National Instruments\LabVIEW 2012\resource\lvanlys.dll" and DLL initialization examples failed. These messages kept popping up for dozens of times and finally a blank "simulation signal" component with no available attribute came up.
I guess the reason of this problem is that I have uninstalled labVIEW2013 on this computer before. When I searched the Internet I found that there is something wrong with the NI uninstallation and after you reinstall it there will be all kinds of problems.
Anyway it is so great that my labVIEW finally works, after I have spent this whole week trying all kinds of methods I can find on the Internet to fix it !
04-29-2014 12:15 PM
Sounds like a bad install. In the future if you see something like this it is best to perform a repair install, instead of copying files from other computers that you assume haven't been tampered with.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-29-2014 07:30 PM
Yeah, and I will be more careful with the installation and uninstallation of softwares.
