02-03-2009 02:05 PM
02-03-2009 02:15 PM
Just a thought on an alternative...
While a low pass filter may help (if you have noise), the approach that we use is to acquire the data at 1kHz and then average 100 samples (so we get data 10 times a second). This has worked exceptionally well for us.
Rob
02-03-2009 03:34 PM
Tim,
Rob's idea is probably what you should try first. It is in effect a low pass filter with about a 10 Hz corner frequency.
If you find that you have strong power line frequency interference, you may need to do more aggressive signal conditioning. Especially watch out for ground loops.
Lynn
