When you right click on a comparator, you have the option to choose to compare elements or aggragate. In this way, you can have an array of results based on the inputs. You can then search the array for elements that were out of range (by searching your results arrays for out-of-range boolean) and then logging those results to file.
If you still have trouble, attach a sample VI with an array of your data (as a constant, or default front panel value) and your limit or limits, and we can show you what to do.
