Peter,
I have done a quick check on Deja and over the course of the last two months
you have posted 16 messages in which the solution of someone's problem was the
application of one of your companies' products.
I for one find this tiresome. If you occasionally want to post a short blurb
on your products that is fine, but not everyone gets much satisfaction from
being told "I'll sell you a product for your problem" when they ask a
technical question in this forum.
Please cease. Thanks in advance.
On 30 Jun 2000 13:52:14 -0500, "Peter Prinzen"
wrote:
>We have your Solution, a labVIEW-Zip Interface. A demo can be found at our
>website, www.xon.de (/indexe.htm)
>Peter
>"R.G. Stockwell" wrote:
>Greetings all!>>Here is my problem, I hope someone can help:>I have an array
>that I write to disk. It is large, and there>are many of these data arrays
>(gigs and gigs of it). I>notice that I can zip it (pkzip on windows) and
>reduce its size>by a factor of ten. I think it would be a much nicer solution>to
>imbed the zipping procedure as a subvi of the write routine,>(and unzipping
>as a subvi in the read routine).>>Does anyone have a vi that can produce
>a compressed file?>(or a dll that I can link in maybe?)>>Also, this is data,
>so the compression must be lossless.>>>I realize I could just zip the data
>in a seperate process, but to have>it "invisible" to the user, and to have
>a standalone vi that can read>and write it would be much nicer.>>>thanks
>in advance,>>bob stockwell>mysurname@co-ra.com>>
Christopher Dubea Phone: (504) 847-2280
Vice President of Engineering Fax: (504) 847-2282
Moving Parts L
.L.C. email: cdubea@movingpart.com
P. O. Box 6117 URL: http://www.movingpart.com
Slidell, LA 70469-6117
