looking for labview routines to read dallas semi 1 wire devices
Installing MS visual J# seems to help. I get a list of objects now to choose from after selecting the assembly.
But what next? 🙂
Message 11 of 14
(2,371 Views)
Yes, that did the trick. However, since there is a mismatch in versions between the one used in Mike's example, the code needs to be rewritten from start (it seems).
nevertheless, the key to getting onewirewiever (1-wire viewer) from Dallas semiconductor to work was to install MS visual J# (beside .Net), actually exactly as it said in the installation for the 1-wire viewer drivers Smiley Very Happy
My application is working now after copying some portions of Mike's example which I needed and with slight modifications.
Message 12 of 14
(2,361 Views)
With dotnet.zip attached with this post we are able to read ID's  of 1-wire devices. Can you please help me on how can I proceed to start a mission, stop mission and loading mission results as in onewireviewer software?
I am using one wire Container 41. Please help me.
Message 13 of 14
(962 Views)
Looking for a 1-wire solution.  Will be running LV2015/Win 7 Pro.
What is the confinguration you would recomend?
John Z.
Message 14 of 14
(855 Views)
