04-01-2005 12:14 PM
04-04-2005 01:32 PM
01-10-2006 01:10 AM
11-19-2010 11:28 AM
Here are the drivers for this, they have been uplifted to Labview 8.2 and seem to work for the most part with LV 8.6
07-18-2011 07:34 PM
Thank you for providing the AQ6317 zip file. Would you happen to know if this file works for the 2010 version of LabVIEW? Version 10.0.1 (32 - bit)? Whenever I try to run the example.vi file, I get the following error...
"Error -1073807346 occurred at VISA Read STB in AQ6317 Read Status.vi->AQ6317 Close.vi->AQ6317 Example.vi
Possible reason(s):
VISA: (Hex 0xBFFF000E) The given session or object reference is invalid."
Anybody know what to do?
Leif
07-18-2011 10:51 PM
07-19-2011 09:17 AM
I haven't tried them with 2010, but I did with 2009 so I think your fine. The other error you are getting seems like set up as the prior poster said. You need to look inside the code and debug as it runs, I seem to remember rewiring something on the block diagram to get it working. Its been a while.
01-17-2012 12:07 PM
Error -1073807346 comes from AQ6317.Close.vi which contains a subVI VISA GPIB Control REN.vi That subVI does not contain any code, just the inputs and outputs and nothing is wired. It is supposed to assert or unassert the GPIB REN line. Thus its VISA session input is not connected to its dup VISA session output and so the VISA session error is produced. The subVI's default mode is to Go to Local (True). Wiring in False will avoid the call to the subVI with the missing code and not produce the error.
Steve
11-11-2014 03:31 AM
Hi, Leif
I have the same problem you have met, could you please tell me how to solve this problem?
Thanks a lot!
Zhang
02-13-2015 12:55 PM
thanks a lot for the vi linked by shredderofmass.
I got it working with our AQ6317 and Labview 2010. Some hints:
Before you are able to start the program, your AQ6317 needs to have a VISA adress and needs to be able to communicate with your pc. To check this, use the NI Automation and Measurement (NI Max). You can change the VISA adress of the AQ6317 by pushing the "System" button and then MY ADR.
If your Ando is not found by the NI MAX, switch it off and on again. If you plug in the connection to the computer while the instrument is running, it does not seem to work.
The VI uses points as a decimal delimiter. If you are in europe and your pc uses kommas, nothing will work! You can change this in your Labview in "Options".
Thanks a lot to you all!
Best regards, Tina
