locking a dial on a control panel
Hello all,
I have created a dial on a control panel.
I notice that I can use the mouse and change the limits on the
range of the dial.
Is there a way for me to lock this so no one else can change it?
thanks,
Richard
(2,546 Views)
Richard
you can right click on dial and select scale->style and then click the blank
setting. You can then either put text labels or string indicator around
your dial to show the dial range.
pat
Richard Harris wrote:
>Hello all,>>I have created a dial on a control panel.>I notice that I can
use the mouse and change the limits on the>range of the dial.>>Is there a
way for me to lock this so no one else can change it?>>thanks,>>Richard>>
(2,546 Views)
Set the "Scale Info.Editable" attribute node to FALSE.
Jean-Pierre Drolet
"Richard Harris" a écrit dans le message news:
39DE4752.65AB612B@kahuna.sdsu.edu...
> Hello all,
> range of the dial.
> thanks,
> Richard
(2,546 Views)
You can use the dials attribute node and set it to "Scale
Info.Editable"; when set to false the user cannot change the scale on
the dial.
ej
In article <39DE4752.65AB612B@kahuna.sdsu.edu>,
> Hello all,
> range of the dial.
> thanks,
> Richard
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,546 Views)
