Therefor you can use the ini file vi's. You can create a new section for
each control and assign the informations (name, flatten data) with
different keys like:
[Control_01]
Name=...
FlattenData=...
[Control_02]
In some cases you are not able to see the real value, for instance the
flatten data. Just try it out.
Henrik
bruyn schrieb:
> I would like to have a vi which creates a human
> readable ascii-file from any vi's front panel.
> If possible with the option to load it back into
> the vi. This way a situation can be saved as kind of a version. Also
> using the same settings in another vi could be handy.
> I have made a vi which makes creates a file containing control names,
> flattened data and typedefs of the controls, but it's binary !
> Is
there a way to translate these codes to uman readable code ?
> This would bring me closer to the solution.
