06-19-2009 11:01 AM - edited 06-19-2009 11:05 AM
I placed two enum controls on a panel and edited them with my desired values. I was able to right-click and "advanced-customize"one into a type def ctl file. When I right-clicked on the second enum, "customize" was grayed out. No problem. I saved my first type def, then deleted and created the two enum controls, made the second enum into a type def and save it. I then deleted both enum controls, dragged and dropped the two type def controls on to my panel. However, now, I can right click on one control and find the "type def" menu options but the other control has the usual non-type def menu options. I redid the drag-and-drop and reversed the order of which control was place on the panel. It seems that the second type def dropped on to the panel retains its 'type def'-ness and the first control becomes a simple enum control. Does LV only allow for one type def per VI?
I'm using Labview 8.6.1
06-19-2009 11:13 AM - edited 06-19-2009 11:14 AM
06-19-2009 11:24 AM
You can have as many typedefs as you want, and you don't need to be deleting anything. The limitation is with the right-click operation of Advanced->Customize. This is limited to only one control editor window open at a time. You can still open up a new control editor window for a second typedef using the File->Open menu option.
This limitation has been addressed in the LabVIEW Idea Exchange.
