BONJOUR.. je suis un etudiant de la faculté de science de monastir .. j'ai un probléme avec la carte myrio.. s'il vous plait je veut realiser un cube a leds 5*5*5 le problème c'est que le courant de sortie des pins A et B sont trés faible de tels façon que la luminosité est trés faible ... comment je peut augmenter le courant de la carte ou bien une autre facon pour augmenter la luminosité? ...
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
And remember that LEDs are current driven devices. In other words, their brightness is a function of their drive current. Voltage is a secondary matter, as long as it isn't so low the things can't operate, or so high they fry, voltage really doesn't matter.
Also since you have 125 LEDs that could all be on at once, make sure your power supply is studly enough.
Mike...
Certified Professional Instructor Certified LabVIEW Architect LabVIEW Champion
