leap sensor not working in .exe
I am interfacing leap sensor with labview. In VI, I am getting the leap data perfectly fine. But when I make the exe, I am not getting the sensor value (leap) other than that all indicators and controls are working fine in .exe.
looking forward for help.
Regards
kashif
Message 1 of 13
(4,589 Views)
I'm afraid you may not get much help because your message is very scarce on information.
Let's start off simple.   What is a "leap sensor"?
Second, show some code or something so we can see how you are interfacing with this sensor.
Message 2 of 13
(4,579 Views)
Attach your VI.  If you are using third-party software, tell us about it.
Message 3 of 13
(4,540 Views)
please find the attach VI. the VI works fine, the problem I am facing is with .exe
Message 4 of 13
(4,507 Views)
Hi kashif,
Which "problem" are you facing? Which error do you get?
Why does your block diagram not look like this:
Why are there terminals without a label?
How is the communication channel defined to your sensor?
Why is there no error handling in the loop?
Again: which error do you get?
Message 5 of 13
(4,495 Views)
I am getting the error
" Error 1172 occurred at Constructor Node Error creating instance of Controller in assembly Leap.Controller, LeapCSharp.NET3.5, Version=0.0.0.0, Culture=neutral, PublicKeyToken=6e1b1368e71eba9b, (System.TypeInitializationException: The type initializer for 'Leap.LeapPINVOKE' threw an exception.
Inner Exception: System.TypeInitializationException: The type initializer for 'SWIGExceptionHelper' threw an exception.
Inner Exception: System.DllNotFoundException: Unable to load DLL 'LeapCSharp': The specified module could not be found. (Exception from HRESULT: 0x8007007E)) ".
you need to install the leap sensor library from the VIPM to find the missing items.
Looking forward for help.
Thanks and regards
kashif
Message 6 of 13
(4,482 Views)
Hi Kashif,
you should have told that error description right in your first message!
So the EXE cannot access that .NET library in the right way.
What does the support for that LEAP sensor toolkit say about this problem?
Message 7 of 13
(4,480 Views)
hello GerdW,
How do I resolve this?
I only find this online
https://www.labviewmakerhub.com/forums/viewtopic.php?f=4&t=309
Thanks and regards
kashif
Message 8 of 13
(4,475 Views)
Hi Kashif,
do the discussion points in your linked thread apply to you?
Message 9 of 13
(4,470 Views)
hello GerdW,
No, because my VI works fine and I am only getting the error in .exe.
thanks and regards
kashif
Message 10 of 13
(4,467 Views)
