lakeshore 330 data sensor vi is not working
I am trying to run a labview program which has one sub vi as Lakeshore 330 Data sensor that should return the sample temparature and controller temparature of the Lakeshore temparature controller 330. However, it does not return the controller temparature and returns only sample temparature.
Please help me out.
(2,910 Views)
Hi
 Before you can read you must first init etc etc.
Goto the examples finder type 330 and there you find an vi that does all the work for you.
instr.lib\Lake Shore Cryotronics 330\Examples\Lake Shore Cryotronics 330 Controller Output.vi
(2,890 Views)
Thank you so much.
I am do not the example while searching as per your guidance through example finder.
I have attached the snapshot of the example finder directory.
Please let me know where to find the example.
Krati
(2,887 Views)
You are looking in the wrong place and did you even install the driver?
(2,884 Views)
Yes, I did.
would you please let me know where to look for that examples?
Krati
(2,881 Views)
Help>Find Examples>Hardware Input & Output>Instrument Drivers>LabVIEW Plug and Play.
(2,877 Views)
Found it.
Thank you.
Krati
(2,866 Views)
