03-27-2022 10:08 PM
I am using labview 2018. I need to call some devices' .dll. The .dll is 64bit.
Shall I use labview 32bit or 64bit in order to call the 64bit .dll?
Or it does not matter?
Jialing
Solved! Go to Solution.
03-27-2022 11:56 PM - edited 03-27-2022 11:58 PM
Use LabVIEW 64-bit to call a 64-bit DLL.
If you can't do this in some circumstance (e.g. you're using 64-bit for a 64-bit DLL, and/or more RAM access, and then you also need a 32-bit DLL) you have to create a matching-bitness application with some method of communicating, e.g. in the example above you could create a 32-bit application that ran alongside your other application and used TCP or Network Streams or similar to communicate between applications. Not ideal...
For more details, see Calling a 32-Bit DLL from 64-Bit LabVIEW and Vice-Versa.
04-04-2022 07:43 PM
Thank you!
It resolved.
