labview square wave measurement problem
Hi Asrih,
why do you want to compare a boolean signal with "greater equal to TRUE"?
This is a classic Rube-Goldberg (and not needed at all)!
Message 11 of 18
(2,469 Views)
Hi GerdW,
so if i take that out (greater/ equal to true) out the LED will stay on if the signal of the DI1 is high/low?
With kind regards
Asrih
Message 12 of 18
(2,463 Views)
but the problem is, if the signal is off the LED should go off too. if the signal is on the LED should stay on and not blink
Message 13 of 18
(2,459 Views)
Hi Asrih,
the "boolean2" LED will stay TRUE once a TRUE value comes from this subVI in your image.
There's a contradiction in these sentences!
Should the LED go off with a FALSE signal - or should it stay ON?
Message 14 of 18
(2,446 Views)
Hi GerdW,
it should go off.
With kind regards,
Asrih
Message 15 of 18
(2,439 Views)
Hi Asrih,
when the LED should go off/FALSE, when the input signal goes FALSE, then it will blink…
What exactly do you want to achieve? Please define your goal without contradictions!
Message 16 of 18
(2,437 Views)
Hi GerdW,
look this is the case,
im making a test for PCB, it has a emergency switch and a buzzer.
case 1: emergency switch isnt pushed, buzzer makes no sound and therefore the LED in my program stays off
case 2: Emergency switch is pushed in, buzzer automaticly makes sound (in a square wave form therefore the simulation). but if i put this in the program the LED will blink.. because the signal is high/low what i want is that the LED will stay on.
(english is not my native langueage thats why i cant explain it very good)
With kind regards,
Asrih
Message 17 of 18
(2,434 Views)
Hi Asrih,
then use the suggestions above to store the TRUE state in a shift register!
As long as your hardware only delivers FALSE values the LED will stay FALSE. As soon as the first TRUE is returned the LED will stay TRUE…
Message 18 of 18
(2,399 Views)
