labview real time vs fpga project
Is there any difference between labview real time project & labview fpga project selection tab provided in the getting started window of labview 8.5? I want to program cRIO module? Which project type I want to select?
(2,565 Views)
In your case its better to use the FPGA project because you will have more options there concerning cRIO.
Christian
(2,545 Views)
I agree with Christian that the FPGA Project Wizard is a better starting point.
If you haven't tried the Real-Time one, try it out and inspect the project and VIs that the Real-Time Wizard generates. It will show you some concepts and ideas that you might want to integrate into your application.
(2,515 Views)
