labview fpga decimation after fir conpiler
We hope to extract the filter output data M times in FPGA and then pass in DMA_FIFO, but the filter output data type is not an array, how to change the data flow into an array ?
(1,787 Views)
Accepted by topic author ninnini
You may use the build array function in LabVIEW to build array.
https://zone.ni.com/reference/en-XX/help/371361J-01/glang/build_array/
(1,754 Views)
Thank you for your answer.
(1,739 Views)
